FAQ FAQ  Forum Search   Calendar   Register Register  Login Login
table repair help needed
 Post Reply Post Reply
Author
  Topic Search Topic Search  Topic Options Topic Options
woodscavenger1 View Drop Down
Craftsman
Craftsman
Avatar
Online Status: Offline
  Quote woodscavenger1 Quote  Post ReplyReply Direct Link To This Post Topic: table repair help needed
    Posted: 08 Feb 2010 at 6:31pm
hi guys i generally live over at the wood turning section but today i have a slight problem with furniture...
my mum gave me one of those mass produced itallian tables with all the patterned inlay but managed to drag the side of it along the pavement when she moved it..... i have repaired the minor scratches on the top which now looks as good as it should using rustins french polish and linseed oil....
on the edges where mum (bless her ) dragged it there were deep scores that went into the wood below.. i have sanded them out really well and feathered the finish..
but when it comes to colouring and finishing i can only do one or the other if i colour first thes colour comes off when i polish if i polish first the polish wont take the colour
if somebody can shed some light on this for me i would be grateful.. if i can i will post some pics to show the extent
thanks in advance
chris
Back to Top
Derek Jones View Drop Down
Magazine Staff
Magazine Staff
F & C Editor
  Quote Derek Jones Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:09pm
Hi Chris
If you could post a pic that would help. Sounds like you're on the right track though. French polish (alcohol based) will remove any spirit based stain unless applied gently with a brush. Ideally you want to put a sealer over the stain (shellac sanding sealer) to fix it but for touching up small areas it's not crucial. You will find it easier if you use an oil stain or water based one. Spirit stains can be added to French polish to adjust the colour as well but use sparingly. Michael Huntley has been dealing with this very subject in the last couple of F&Cs. Have a look under Techniques on this Home Page for one of them.
But as I say, a pic would help.
Derek
Back to Top
Sal View Drop Down
Apprentice
Apprentice
  Quote Sal Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:46pm
Spray it!!!
I hear a big gasp from all the craftsmen. After all, the Italians have sprayed it to death. You can colour it and use an aersol lacquer over it- bingo!
Back to Top
P Grogan View Drop Down
Veteran Craftsman
Veteran Craftsman
Avatar
  Quote P Grogan Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:51pm
Hi Chris,
If the scratches are really deep you can use shellac bars see the link.  You melt them into the scratch or hole; note they are NOT wax they are solid shellac and so will take sanding down to really fine and French polish as well as oils and friction polishes.  You can blend colours to make others and you can shape it to follow contours using an iron or soldering iron, I tend to heat the end of a 10cm metal rule and push it into the repair area.  Because its not wax it doesn't interfere with any of the finishes that I know of.
Look at the shellac filler sticks
PG
Edited by P Grogan - 08 Feb 2010 at 8:53pm
Back to Top
Craftsman
Craftsman
Avatar
  Quote woodscavenger1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 2:08pm
thanks guys i really appreciate the advice and as soon as i have time i will post before and afters for your corrections and improvements.... well i am only a beginner you know
cheers again
chris
Back to Top
Forum Jump Forum Permissions View Drop Down
Bulletin Board Software by Web Wiz Forums® version 9.50
Copyright ©2001-2008 Web Wiz
This page was generated in 0.078 seconds.
