Router cutters for Maloof Inspired Rocker - HELP |
Post Reply
| Author | |
mellpack
Apprentice
Joined: 17 Oct 2009 Location: Eastbourne Online Status: Offline Posts: 12 |
Quote Reply
Topic: Router cutters for Maloof Inspired Rocker - HELPPosted: 26 Jan 2012 at 5:22pm |
In the process of building the Maloof Inspired Rocker (using Charles Brock's plans).
Does anyone know a source for one of the router cutters required for the leg joinery: Rabbet bit with 1 1/2" diameter and 1/2" rebate (preferably 1/2" shank). I've ordered from Rutlands, but they are out of stock and not due in till the end of March! Axminster and DMTools don't carry it surprisingly. I have the roundover bit with 3/4" radius, although only a 1/4" shank, so I guess I could make up a jig to cut the mortice with a straight cutter and guide bush, but it's not ideal. Any thoughts? |
Walter Hall
Moderator
Joined: 10 Sep 2008 Location: Northumberland Online Status: Online Posts: 7323 |
Quote Reply
Posted: 26 Jan 2012 at 5:43pm |
Wealden Tool Co do a 38mm (1 1/2 in)one which has a 12.7mm (1/2 in) rebate.
T1714-1/2 cutter with TB501 bearing Walter |
Lost Head
Craftsman
Joined: 12 May 2009 Online Status: Offline Posts: 407 |
Quote Reply
Posted: 26 Jan 2012 at 7:38pm |
You could also look at Infinty. They had a good write up in an earlier mag. I also have a set which have been very good.
Andy |
mellpack
Apprentice
Quote Reply
Posted: 26 Jan 2012 at 7:56pm |
Thank you both, I'll look into those.
mellpack
Apprentice
Quote Reply
Posted: 18 Feb 2012 at 12:28pm |
Sorry to take so long to update you all. I've ben laid low by a virus.
So, how did I get on? I decided to opt for Infinity Tools. Both cutters were in stock, and they were delivered the following day. These are not cheap cutters, and I was pleased to find that they appeared to be well designed and manufactured, and they cut extremely cleanly. I did have a minor problem, in that the fitted bearing on the rebate cutter was of the wrong diameter, however Paul at Infinity was most appologetic and I soon had a replacement bearing to correct the issue. Now, as a little bonus, I can cut 3/8" or 1/2" rebates with the cutter! My chair leg joints look pretty good, and I can't wait to finish the rocker off. |
Post Reply
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
